MGL Avionics Альтиметр вариометр ALT-6
sprint2003
http://xn--80a2afj3a1ak.xn--p1ai/
MGL Avionics Альтиметр вариометр ALT-6 НОВЫЙ
ALT-6 Altimeter and Vertical Speed Indicator (VSI)
ALT-6 Pic
The ALT-6 is a 3 1/8” sunlight readable encoding altimeter and a wide range vertical speed indicator.
The altimeter contains an internal high accuracy 24 bit digital altitude sensor which calculates altitude from -1000 ft up to a maximum of 35000 ft. The ALT-5 outputs various formatted RS232 serial data protocols compatible with serial input transponders such as that from Garmin, Magellan, Northstar, Trimble, Microair etc. The altimeter can display altitude in feet or meters and local pressure can be set in millibars or inches of mercury
The VSI indicator can be displayed in either feet/minute (ft/min) or meters/second (m/s). The VSI can be calibrated by the user once the instrument has been installed in the aircraft.
The ALT-6 also features a user settable altitude bug and an encoder test function. Please see the Blaze ALT-7 if you require a parallel Gillham code interface. Alternatively the ALT-6 provides a parallel Gillham code interface when used in conjunction with the MGL Avionics CNV-ALT.
Features
  • Large 2.6” high resolution 320x240, IPS (fully viewable in all directions), sunlight readable color LCD display
  • An internal high accuracy 24 bit digital altitude sensor calculates altitude from –1000 ft up to a maximum of 35000 ft (-304m to 10668m)
  • The ALT-6 outputs various formatted RS232 serial data protocols compatible with serial input transponders such as that from Garmin, Magellan, Northstar, Trimble, Microair etc.​
  • Provides a parallel Gillham code interface for transponders when used in combination with the MGL Avionics CNV-ALT. Please also see the Blaze ALT-7 if a parallel Gillham code interface is required.
  • Built in encoder test function
  • The altimeter can display altitude in feet or meters
  • Local pressure can be set in millibars or inches of mercury
  • Contains a wide range VSI indicator from +/-20 ft/min to as high as +/-10000 ft/min
  • VSI units can be in feet/minute (ft/min) or in meters/second (m/s)
  • User settable altitude bug
  • Standard 3 1/8” aircraft enclosure (can be front or rear mounted)
  • The LED backlight can automatically adjust to the ambient light, or it can be manually adjusted in the menu system
  • Rotary control plus 2 independent buttons for easy menu navigation and user input
  • Wide input supply voltage range of 8 to 30V DC with built in voltage reversal and over voltage protection for harsh electrical environments
51000 руб
Самовывоз Озерная 42
или отправлю
+7916922287ноль
