Летательный аппарат Kasperwing
а жёсткое крыло будет иметь лучшие характеристики?И на сколько?
-[ch1091] [ch1078][ch1105][ch1089][ch1090][ch1082][ch1086][ch1075][ch1086] [ch1082][ch1088][ch1099][ch1083][ch1072] [ch1087][ch1088][ch1086][ch1092][ch1080][ch1083][ch1100] [ch1053][ch1040][ch1050][ch1040]8-[ch1061]-12\[ch1074][ch1077][ch1088][ch1090][ch1086][ch1083][ch1105][ch1090][ch1085][ch1099][ch1081]\.
-[ch1091] [ch1087][ch1083][ch1072][ch1085][ch1077][ch1088][ch1072] \[ch1041][ch1050][ch1041]1-[ch1040]\ [ch1087][ch1088][ch1080] [ch1091][ch1076][ch1083][ch1080][ch1085][ch1077][ch1085][ch1080][ch1080] 10 [ch1082][ch1072][ch1095][ch1077][ch1089][ch1090][ch1074][ch1086]=29!
-[ch1091] [ch1087][ch1083][ch1072][ch1085][ch1077][ch1088][ch1072] /[ch1041][ch1069][ch1050][ch1040][ch1057]-[ch1053]\ [ch1089] [ch1091][ch1076][ch1083][ch1080][ch1085][ch1085].=15  [ch1082][ch1072][ch1095][ch1077][ch1089][ch1090][ch1074][ch1086]=44!
[ch1089][ch1074][ch1086][ch1081][ch1089][ch1090][ch1074][ch1086] [ch1087][ch1072][ch1088][ch1072][ch1096][ch1102][ch1090][ch1080][ch1088][ch1086][ch1074][ch1072][ch1085][ch1080][ch1103] [ch1080] [ch1082][ch1091][ch1074][ch1099][ch1088][ch1082][ch1086][ch1074]=[ch1089][ch1086][ch1093][ch1088][ch1072][ch1085][ch1103][ch1077][ch1090][ch1089][ch1103].
[ch1089][ch1086][ch1074][ch1089][ch1077][ch1084] [ch1076][ch1072][ch1078][ch1077] [ch1085][ch1077] [ch1087][ch1083][ch1086][ch1093][ch1086]\[ch1077][ch1089][ch1083][ch1080] [ch1087][ch1088][ch1080][ch1076][ch1077][ch1083][ch1072][ch1090][ch1100] [ch1087][ch1086][ch1083][ch1091][ch1095][ch1096][ch1077] [ch1092][ch1102][ch1079][ch1077][ch1083][ch1103][ch1078],
[ch1073][ch1091][ch1076][ch1077][ch1090] [ch1077][ch1097][ch1105] [ch1083][ch1091][ch1095][ch1096][ch1077]\.
http://kasperwing.com/KasperwingAutomatedImageBank/displayimage.php?album=1&pos=8
-podgotovka k konstrukcii kompozitnogo kryla KASPERa...
http://kasperwing.com/KasperwingAutomatedImageBank/displayimage.php?album=random&cat=&pos=-11
-vietshierom,po malopolskomu niebu....
Это проверено на практике или только теоретические расчеты?
-provierieno a u BEKAS-N obnoruzylos unikalnoje svojstvo lietat dynamitsheski,s ispolzovanijem energii poryvov vietra
\na malyh vysotah,pierielioty biez tiermiki\
"The American FAA cannot but give Kasprzyk the certificate that allows him for acrobatics on BKB without height limit."!!!
http://www.twitt.org/KASPBIBLIO.html#KASPERBIBLIO
-litieratura dostupnaja v TWITT.
http://www.twitt.org/April05Ltrrev.pdf
-gazieta TWITT...
http://www.nurflugel.com/Nurflugel/Papers/George-Falvy/Falvy_29/falvy_29.html
-stoit vnimatielno rassmotriet!
/sravnienije BKB s HORTEN IV/
KASPERWING=также как и шампунь=ДВА В ОДНОМ!
-а серьёзно=у крыла КАСПЭРа свойственна СТАТИЧЕСКАЯ
стабильность и управляемость...
это позволяет ему лететь как обычное крыло\с хорошим
качеством\ но также подходить вертикально на посадку\с возможностью управления вокруг верикальной оси\.
Просто так,"по щучьему велению" в аэродинамике ничего не бывает.Всему есть разумное объяснение.
Но есть и мифы.
Почему аппарат 1-80 с малым углом стреловидности устойчиво парашютирует? Что не позволяет ему входить в кувырок? У крыла этого аппарата нет НИКАКИХ хитрых аэродинамических причиндалов,кроме концевых шайб- рулей обеспечивающих управляемость!
Некоторые размышления по поводу К аппаратов 1-80.
Оно якобы меняется от 10 у В(вполне правдоподобно) с открытой тележкой,до 15 у ВХ с обекателем телеги.Поскольку на режиме Кмах Схi = Схо, за счёт обтекателя Схо должен уменьшиться в 3 раза! Используя данные по Сх тележек из книги "Мотодельтапланы" А.П.Клименко и И.В.Никитина,я получил изменение Сх0=0,01 (для этого аппарата).
Думаю,такое увеличение К за счёт обтекателя тележки-это рекламный вымысел 🙁
Хенрик, на сайте КасперВинга я обнаружил фото, в названии которого встретилось знакомое имя!
Меня приятно удивило, что профиль и управление КасперВинг можно совмещать со свободно подвешенным крылом FreeWing (Spratt).  Облетан и такой вариант?!
По-прежнему ли позволяет сильно S-образный профиль (и хитрые шайбы) КасперВинга создавать над крылом вихрь, обеспечивающий режим парашютирования?!
Управление по тангажу хотя и остается балансирным (?), но приобретает для этого подвижную ручку, и не нужно быть подвешенным в "люльке". (Наверное это предподчтительно для аварийного покидания аппарата?).
Правда, приобретенный стиль движения ручкой - не самолетный.
Как Вы думаете, стоит ли думать над переделкой ручки управления так, чтобы стиль управления стал бы совместимым с самолетным?
А может быть уже известны такие, - самолетные, решения РУС по тангажу для КасперВинга, совмещенного с ФриВингом?
    41,6 КБ · Просмотры: 291
Хенрик, а существует ли одноместный вариант Kaspewing с полностью аэродинамическим управлением?
"vortex augmented lift"
-посмотрите в поисковике.там тоже аэродинамика,
но более расширенная.
пример использования генераторов вихрей Каспэра=
http://www.youtube.com/watch?v=yuP7Qm1OmIg&feature=related
-обратите внимание на переднюю кромку\0.36-0.38 мин\...
-[ch1073][ch1099][ch1083] [ch1074][ch1072][ch1088][ch1080][ch1072][ch1085][ch1090]\180[ch1094][ch1088]\ [ch1086][ch1076][ch1085][ch1086][ch1084][ch1077][ch1089][ch1090][ch1085][ch1086][ch1075][ch1086] [ch1089] [ch1087][ch1086][ch1083][ch1085][ch1086][ch1089][ch1090][ch1100][ch1102] [ch1072][ch1101][ch1088][ch1086][ch1076][ch1080][ch1085].[ch1091][ch1087][ch1088][ch1072][ch1074][ch1083][ch1077][ch1085][ch1080][ch1077][ch1084]
\[ch1089][ch1072][ch1084][ch1086][ch1083][ch1105][ch1090][ch1085][ch1086][ch1077]\ [ch1085][ch1086] [ch1085][ch1077] [ch1087][ch1086][ch1083][ch1091][ch1095][ch1080][ch1083] [ch1088][ch1072][ch1089][ch1087][ch1088][ch1086][ch1089][ch1090][ch1088][ch1072][ch1085][ch1077][ch1085][ch1080][ch1103]...
http://kasperwing.com/Kasperwing%20images/180cr.jpg
-[ch1082][ch1086][ch1085][ch1089][ch1090][ch1088][ch1091][ch1082][ch1090][ch1086][ch1088]\[ch1057][ch1090][ch1080][ch1074] [ch1043][ch1088][ch1086][ch1089][ch1089][ch1088][ch1072][ch1082]\ [ch1076][ch1086] [ch1089][ch1080][ch1093] [ch1087][ch1086][ch1088] [ch1083][ch1077][ch1090][ch1072][ch1077][ch1090] [ch1085][ch1072] 1-80,
[ch1089][ch1090][ch1088][ch1077][ch1084][ch1083][ch1077][ch1085][ch1080][ch1103] [ch1082] [ch1087][ch1077][ch1088][ch1077][ch1076][ch1077][ch1083][ch1082][ch1072][ch1084] [ch1085][ch1077][ch1090].
можно совмещать
-облётан,но из-за технических ошибок летал неустойчиво...
одну из них можно заметить на этом снимке=
http://kasperwing.com/KasperwingAutomatedImageBank/displayimage.php?album=random&cat=&pos=-111
а вторую на этом=
http://kasperwing.com/KasperwingAutomatedImageBank/displayimage.php?album=1&pos=30
Перевод статьи “Some Ideas of Vortex Lift”, by Witold A. Kasper
http://narod.ru/disk/18812520000/%E2%80%9CSome%20Ideas%20of%20Vortex%20Lift%E2%80%9D%2C%20by%20Witold%20A.%20Kasper.djvu.html
-был вариант\180цр\ одноместного с полностью аэродин.управлением
\самолётное\ но не получил распространения...
Странно... Если поверить ВСЕМУ,что написано и сказано про аппарат 1-80,то на нём лучше всего претендовать на победу в чемпионатах по СЛА!
Но нет этого!? :-?
Я думал,что подвеска пилота во многом сдерживает его распространение.Вот и Хенрик с друзьями делают свой аппарат по- человечески 😉
-[ch1087][ch1088][ch1086][ch1089][ch1100][ch1073][ch1072] [ch1082] [ch1042][ch1080][ch1082][ch1090][ch1086][ch1088][ch1091]\[ch1080][ch1083][ch1080] [ch1076][ch1088][ch1091][ch1075][ch1086][ch1084][ch1091] [ch1091][ch1084][ch1077][ch1083][ch1100][ch1094][ch1091]\=[ch1074][ch1099][ch1076][ch1077][ch1083][ch1080][ch1090][ch1077] [ch1087][ch1086][ch1078][ch1072][ch1083][ch1091][ch1081][ch1089][ch1090][ch1072] [ch1089][ch1085][ch1080][ch1084][ch1086][ch1082] [ch1080][ch1079] [ch1074][ch1080][ch1076][ch1077][ch1086]
[ch1095][ch1090][ch1086][ch1073][ch1099] [ch1073][ch1099][ch1083][ch1086] [ch1074][ch1080][ch1076][ch1085][ch1086] "[ch1076][ch1086][ch1089][ch1082][ch1080]"-[ch1075][ch1077][ch1085][ch1077][ch1088][ch1072][ch1090][ch1086][ch1088][ch1099] [ch1074][ch1080][ch1093][ch1088][ch1077][ch1081].
-просьба к Виктору\или другому умельцу\=выделите пожалуйста снимок из видео
чтобы было видно "доски"-генераторы вихрей.
    181,7 КБ · Просмотры: 282
